Banging in engine knocking bearing noises .wt happen it die driveway will it happen again . Wt should I do wt it
You should have it towed to a good independent mechanic. Starting/driving it may do damage.
Bring a good line of credit wt you.
Sounds like the damage is done, replace the engine or sell the vehicle.
And then probably send it to the junkyard.
Is the oil at the correct level?
