2007 Chrysler PT Cruiser - Battery drain
Battery goes dead if left in garage for a week or two.small electric drain?
The BEST Way TO Perform a Parasitic Draw Test - YouTube
how old is your battery? have it checked out.
check to make sure there are no lights staying on. like glove box or under hood light if you have one. also check to make sure the brake lights are not stuck on. this could happen intermittently if you have a bad brake light switch.
Be aware that the vehicle has the infamous Chrysler TIPM.
