2007 BMW X3 leaking oil
Oil leakage from the engine, ABS Light showing and 4x4 Light is also showing
ABS light is on because the 4x4 light is on.
Is it in 4 wheel drive ?
BMW X3 is permanent 4x4 (awd), it uses the wheel speed sensors for abs and 4x4
That would almost surely indicate a need for either replacing a gasket, or–possibly–re-torqueing some bolts, but without knowing exactly where the engine’s oil leak is located, nobody could possibly give you a definitive answer.
In any event, unless you are a skilled diagnostician/mechanic, you need to take your vehicle to a qualified mechanic. I strongly suggest looking for an independent foreign car specialist in your area, as repairs at BMW dealerships are quite pricey.
