Anti-coolant drains out under the drivers side
are you sure it’s antifreeze draining and not water from an A/C drain? Regardless, I would get your Audi to a mechanic right away. If you’re loosing antifreeze you could overheat the engine and cause more serious problems
It sounds like you better get the leak found and repaired before your engine overheats.
