battery is losing charge. battery approx 2mos old battery checked by auto zone approx 3 wks ago,good battery… some days my 2007 acura mdx will start and others want…I am reading the Hands Free link is some owners the same problem… how do my son disconnect it.
If you haven’t had the alternator checked out then you should have that tested to check the charging condition. If the trouble is due to a current draw on the battery while the engine is shut off then you need to hunt down the circuit causing the trouble. Here is a link to help you do that.
