2006 Toyota 4Runner - Gas cap?
check engine light came on. Changed gas cap with new Toyota cap from my dealer. What else may cause this light to come on?
since you asked here’s a list of codes. you can go to your local auto parts and get your vehicle scanned. most will do it for free. then you can come back with the code and we may be able to help you better.
Diagnostic Codes - Toyota
On-Board Diagnostics II OBDII
OBD II TROUBLE CODES
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch β€œA” Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch β€œA” Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch β€œA” Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch β€œA” Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch β€œA” Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor β€œA” Circuit Malfunction
P0181 Fuel Temperature Sensor β€œA” Circuit Range/Performance
P0182 Fuel Temperature Sensor β€œA” Circuit Low Input
P0183 Fuel Temperature Sensor β€œA” Circuit High Input
P0184 Fuel Temperature Sensor β€œA” Circuit Intermittent
P0185 Fuel Temperature Sensor β€œB” Circuit Malfunction
P0186 Fuel Temperature Sensor β€œB” Circuit Range/Performance
P0187 Fuel Temperature Sensor β€œB” Circuit Low Input
P0188 Fuel Temperature Sensor β€œB” Circuit High Input
P0189 Fuel Temperature Sensor β€œB” Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction β€” Cylinder #1
P0202 Injector Circuit Malfunction β€” Cylinder #2
P0203 Injector Circuit Malfunction β€” Cylinder #3
P0204 Injector Circuit Malfunction β€” Cylinder #4
P0205 Injector Circuit Malfunction β€” Cylinder #5
P0206 Injector Circuit Malfunction β€” Cylinder #6
P0207 Injector Circuit Malfunction β€” Cylinder #7
P0208 Injector Circuit Malfunction β€” Cylinder #8
P0209 Injector Circuit Malfunction β€” Cylinder #9
P0210 Injector Circuit Malfunction β€” Cylinder #10
P0211 Injector Circuit Malfunction β€” Cylinder #11
P0212 Injector Circuit Malfunction β€” Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch β€œB” Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch β€œB” Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch β€œB” Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch β€œB” Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch β€œB” Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch β€œC” Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch β€œC” Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch β€œC” Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch β€œC” Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch β€œC” Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 β€” Misfire Detected
P0302 Cylinder #2 β€” Misfire Detected
P0303 Cylinder #3 β€” Misfire Detected
P0304 Cylinder #4 β€” Misfire Detected
P0305 Cylinder #5 β€” Misfire Detected
P0306 Cylinder #6 β€” Misfire Detected
P0307 Cylinder #7 β€” Misfire Detected
P0308 Cylinder #8 β€” Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 β€” Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 β€” Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 β€” Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 β€” Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 β€” Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 β€” Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 β€” Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 β€” Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 β€” Circuit High Input (Bank #2)
P0334 Knock Sensor #2 β€” Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor β€œA” Circuit Malfunction
P0336 Crankshaft Position Sensor β€œA” Circuit Range/Performance
P0337 Crankshaft Position Sensor β€œA” Circuit Low Input
P0338 Crankshaft Position Sensor β€œA” Circuit High Input
P0339 Crankshaft Position Sensor β€œA” Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil β€œA” Primary/Secondary Circuit Malfunction
P0352 Ignition Coil β€œB” Primary/Secondary Circuit Malfunction
P0353 Ignition Coil β€œC” Primary/Secondary Circuit Malfunction
P0354 Ignition Coil β€œD” Primary/Secondary Circuit Malfunction
P0355 Ignition Coil β€œE” Primary/Secondary Circuit Malfunction
P0356 Ignition Coil β€œF” Primary/Secondary Circuit Malfunction
P0357 Ignition Coil β€œG” Primary/Secondary Circuit Malfunction
P0358 Ignition Coil β€œH” Primary/Secondary Circuit Malfunction
P0359 Ignition Coil β€œI” Primary/Secondary Circuit Malfunction
P0360 Ignition Coil β€œJ” Primary/Secondary Circuit Malfunction
P0361 Ignition Coil β€œK” Primary/Secondary Circuit Malfunction
P0362 Ignition Coil β€œL” Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal β€œA” Malfunction
P0371 Timing Reference High Resolution Signal β€œA” Too Many Pulses
P0372 Timing Reference High Resolution Signal β€œA” Too Few Pulses
P0373 Timing Reference High Resolution Signal β€œA” Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal β€œA” No Pulses
P0375 Timing Reference High Resolution Signal β€œB” Malfunction
P0376 Timing Reference High Resolution Signal β€œB” Too Many Pulses
P0377 Timing Reference High Resolution Signal β€œB” Too Few Pulses
P0378 Timing Reference High Resolution Signal β€œB” Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal β€œB” No Pulses
P0380 Glow Plug/Heater Circuit β€œA” Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit β€œB” Malfunction
P0385 Crankshaft Position Sensor β€œB” Circuit Malfunction
P0386 Crankshaft Position Sensor β€œB” Circuit Range/Performance
P0387 Crankshaft Position Sensor β€œB” Circuit Low Input
P0388 Crankshaft Position Sensor β€œB” Circuit High Input
P0389 Crankshaft Position Sensor β€œB” Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor β€œA” Circuit Low
P0406 Exhaust Gas Recirculation Sensor β€œA” Circuit High
P0407 Exhaust Gas Recirculation Sensor β€œB” Circuit Low
P0408 Exhaust Gas Recirculation Sensor β€œB” Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve β€œA” Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve β€œA” Circuit Open
P0414 Secondary Air Injection System Switching Valve β€œA” Circuit Shorted
P0415 Secondary Air Injection System Switching Valve β€œB” Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve β€œB” Circuit Open
P0417 Secondary Air Injection System Switching Valve β€œB” Circuit Shorted
P0418 Secondary Air Injection System Relay β€œA” Circuit Malfunction
P0419 Secondary Air Injection System Relay β€œB” Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan #1 Control Circuit Malfunction
P0481 Cooling Fan #2 Control Circuit Malfunction
P0482 Cooling Fan #3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch β€œA” Circuit Malfunction
P0572 Cruise Control/Brake Switch β€œA” Circuit Low
P0573 Cruise Control/Brake Switch β€œA” Circuit High
P0574 Through P0580 Reserved for Cruise Codes
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output β€œA” Malfunction
P0609 Control Module VSS Output β€œB” Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp β€œL” Control Circuit Malfunction
P0622 Generator Field β€œF” Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch β€œB” Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch β€œB” Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch β€œB” Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear #1 Incorrect Ratio
P0732 Gear #2 Incorrect Ratio
P0733 Gear #3 Incorrect Ratio
P0734 Gear #4 Incorrect Ratio
P0735 Gear #5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid β€œA” Malfunction
P0751 Shift Solenoid β€œA” Performance or Stuck Off
P0752 Shift Solenoid β€œA” Stuck On
P0753 Shift Solenoid β€œA” Electrical
P0754 Shift Solenoid β€œA” Intermittent
P0755 Shift Solenoid β€œB” Malfunction
P0756 Shift Solenoid β€œB” Performance or Stuck Off
P0757 Shift Solenoid β€œB” Stuck On
P0758 Shift Solenoid β€œB” Electrical
P0759 Shift Solenoid β€œB” Intermittent
P0760 Shift Solenoid β€œC” Malfunction
P0761 Shift Solenoid β€œC” Performance Or Stuck Off
P0762 Shift Solenoid β€œC” Stuck On
P0763 Shift Solenoid β€œC” Electrical
P0764 Shift Solenoid β€œC” Intermittent
P0765 Shift Solenoid β€œD” Malfunction
P0766 Shift Solenoid β€œD” Performance Or Stuck Off
P0767 Shift Solenoid β€œD” Stuck On
P0768 Shift Solenoid β€œD” Electrical
P0769 Shift Solenoid β€œD” Intermittent
P0770 Shift Solenoid β€œE” Malfunction
P0771 Shift Solenoid β€œE” Performance Or Stuck Off
P0772 Shift Solenoid β€œE” Stuck On
P0773 Shift Solenoid β€œE” Electrical
P0774 Shift Solenoid β€œE” Intermittent
P0780 Shift Malfunction
P0781 1–2 Shift Malfunction
P0782 2–3 Shift Malfunction
P0783 3–4 Shift Malfunction
P0784 4–5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1–4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1–4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100 Barometric Pressure Sensor Circuit Fault
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ETCS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electric Throttle Control System Malfunction
P1130 A/F Sensor Circuit Range / Performance Malfunction (Bank #1 Sensor #1)
P1133 A/F Sensor Circuit Response Malfunction (Bank #1 Sensor #1)
P1135 A/F Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P1150 A/F Sensor Circuit Range / Performance Malfunction (Bank #2 Sensor #1)
P1153 A/F Sensor Circuit Response Malfunction (Bank #2 Sensor #1)
P1155 A/F Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P1200 Fuel Pump Relay Circuit Fault
P1300 Igniter Circuit Fault (Bank #1)
P1305 Igniter Circuit Fault (Bank #2)
P1310 Igniter Circuit Fault (Bank #3)
P1315 Igniter Circuit Fault (Bank #4)
P1320 Igniter Circuit Fault (Bank #5)
P1325 Igniter Circuit Fault (Bank #6)
P1330 Igniter Circuit Fault (Bank #7)
P1335 Crankshaft Position Sensor Circuit Fault (during engine running)
P1340 Igniter Circuit Fault (Bank #8)
P1400 Sub-Throttle Position Sensor Circuit Fault
P1401 Sub-Throttle Position Sensor Performance
P1500 Starter Signal Circuit Fault
P1510 Air Volume Too Low With Supercharger On
P1520 Stop Light Switch Signal Malfunction
P1600 ECM Battery Back-up Circuit Fault
P1633 ECM Malfunction (ETCS Circuit)
P1605 Knock Control CPU Fault
P1700 Vehicle Speed Sensor Circuit Fault
P1705 Direct Clutch Speed Sensor Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park Neutral Position Switch Fault
Good Grief WW , are trying to make this persons eyes cross ?
I was trying to make a point.
W-W, I was going to say, about a thousand other problems, but your post makes the point better.
And a well made point it is. The OP needs to find out what’s causing the check engine light and then address the problem.
How long did it take to type all that?
A loose gas cap or a defective one will throw a (PO455 code).Buy a cheap OBD2 scanner and scan for codes.
I hope for his sanity he copied and pasted it…
Why…you do easily look this up with Google.
Sure…but @weekend-warrior was trying to make a point to our latest drive-by no response OP.
I’m not disputing that. What I’m disputing is the point about c
Wouldn’t it have been easier to just post the link?
Gotcha! Frankly, yes, and it’s what I would’ve done
I doubt if Richy28 will return . But I think posting that entire list of codes was overkill and showing off at the same time. All that was necessary was to say have the codes read and post them back here or use a web search to see what they mean.
The OP didn’t even have the code read, do you really think they would tap on a link?
Depends on the phone/tablet/computer you are using.
Copy&paste is usually easier for me.
And how often has that been successful on the β€œDrive by” catagory, AKA, β€œAsk someone”?
I wonder just how beneficial the Ask Someone site is . It does not seem to draw new members or even clear posts that can be understood.
To clear things up… yes, I copied and pasted it. Usually, I post a link but, in this case, I thought it would be eye opening since OP just changed the cap without even knowing what the code was or having an idea what the problem could be. and OP did ask what else the problem could be. so, I showed him/her. LOL
If the presence of a CEL simply meant β€œgas cap may be loose”, then there would likely be a warning light specifically stating that situation. (Actually, I think that GM used to have such a specific warning light…)
While that very long list might be considered overkill, I think that it was instructive for the OP to see the incredibly large number of trouble codes that could have triggered the CEL. And, I agree that the OP might not have clicked on a link, so I think weekend-warrior was trying to provide a helpful learning experience for the OP.
