About a couple of weeks ago my 2006 Tucson started to tremble sometimes when I drove it. It only has 1004000 miles on it. The trembling was pretty bad today & the engine light came on and stayed on. I checked all the fluids under the hood. No problems there. I always kept up my Maintenace on time. I never had any problems like this before. Has anyone had this particular issue with the 2006?
Yes, ten character minimum.
1004000 has to be a record for a Tucson . 62000 miles a year is a lot of driving.
I missed the zero on the trend. Al Bundy had a million on his Duster!
ii there a check engine light on?
it might be time for new spark plugs. usually changed at 100k miles
The engine has a misfire, likely caused by a failing ignition coil or spark plug.
