is my block cracked? car won’t hold water. after over heating. its not a hose.
Absolutely no way to tell whether the block is cracked or not from out here on the internet. Time to take it into the repair shop. Expect a large bill. Be insanely happy if it is a small bill.
My skills as a mechanic are not even close to other members’ here but doesn’t an overheating often result in a warping of a part that seats against anothermetal part?
No one here…over the net…can inspect your engine block.
Where is the water leaking out. In front by the pulleys …if you are lucky…would be that the water pump has gone out.
Yosemite
