2006 Ford Five Hundred - Dead battery
Battery is dead, can’t don’t know why
That’s easy enough to check.
Could be:
Battery needs replacement.
Alternator has failed.
Parasitic drain.
Was your alternator light on? CEL on?
No just the light for the battery,
Everything would go out in the dash
~}Michelle Little{~
If the battery icon is lit while the engine is running it indicates a charging system failure, possibly an alternator failure.
Alright , I will have it looked at where
I bought the car… thank you all
~}Michelle Little{~
