“NEW” factory engine now has 10,000 miles and I have replaced the fuel pressure sensor twice in the last two months (5.4 lariat).would another part make this happen so often? Help! getting expensive. THANKS jj
That being the case, I would suspect that the real trouble isn’t with the sensor itself but within the wiring connection to the sensor. Assuming that there is wiring to it at least.
