2006 Chevrolet HHR stalling
Car starts, warms up, and as it warms up to operating temperature the idle begins to fluctuate and bounce back and forth between 800rpm & 200rpm, and eventually it stalls out.
Fine while driving around as long as revs kept above 1000rpm.
We’ve replaced MAP sensor, coolant temp sensor and thermostat, throttle body, accel pedal and sensor, coil and ICM, cleaned injectors, new air filter, oil and oil filter, trans fluid and filter, and inspected hoses and intake for vacuum leaks using carb cleaner spray method. Replaced the computer and had it re-flashed. Pulled the plugs and they are fine and gapped correctly. Tested fuel pressure at rail and it is fine.
Nothing is working to solve this and I have no new codes or CEL showing.
Tomorrow I’m pulling the O2 sensors, cleaning, and re-installing, pulling the fuse bank, cleaning contacts, and reinstalling with dialectric grease. Also going to pull the alternator connector, clean, and dialectric grease.
What are we missing?
In that extensive list of things you have checked or replaced I didn’t see the Idle air control valve.
2006 HHR 2.2 Ecotec doesn’t have an IACV.
Other considerations are the crankshaft position sensor, timing chain and tensioner, and body electrical ground straps. Trying to fit it all in tomorrow.
I thought it did because Rock Auto sell a connector for it. Sorry
Unplug the Mass Air Flow sensor and start the engine, if the problem is gone the MAF is dirty or has failed.
It is a brand new mass airflow sensor.
Just put it in yesterday.
Could all of this be related to getting parts from auto zone instead of from the dealer?
Duralast parts vs. ACDelco…?
I have also had two other pro mechanics look at it all, and use a $7k scam tool and they also really didn’t know what is going on. One of them is my mother’s fiancé and he ended up finding a computer from another HHR and then having it reflashed at a local Chevy dealer.
Nothing seems to be fixing the issue. It is very frustrating.
Only code is Random Engine Misfire P0300…
No…
