car runs fine sometimes other times car acts like it is not getting any gas and loses power on acceleration
Well, since you did not ask a question, my crystal ball will leave you with this…
Buick Recall 14299: Ignition Switch May Turn Off — 2006 LaCrosse | CarComplaints.com
No acceleration or RPM increase while pressing gas pedal … (yourmechanic.com)
also a possible faulty fuel pump.
A clogged cat could cause that symptom too. Sometimes a damaged cat will sporadically act like it isn’t clogged b/c the substrate shifts enough (for example as a result of going over a bump) to allow the exhaust gasses to temporarily pass unobstructed.
I’ve had that problem due to a clogged fuel injection system too.
