I have an 05 corolla XRS. I just had a sport clutch put in about 1 year ago. Whenever I shift into 4th gear and accelerate, the RPMs drop about 500 and I lose power for about 3 seconds before it starts going back up. Other gears are acting normal. Best part is that I let my friend drive the car earlier and since he did it’s been doing this. Any ideas?
I went back out last night to check Caddyman but it didn’t happen. Then again today it did it and also in 3rd gear. I noticed if I let the clutch 100% of the way out before putting on any acceleration after shifting it would happen less. No check engine light just the maintenance light for an oil change. I shifted from both low RPMs and high RPMS and issue was consistent.
I may have phrased that wrong. I meant it tends to happen less if once the clutch pedal is out all the way, I wait an additional second before accelerating.
To be clear, you’re at, say, 2500 rpm in 3rd, and you shift to 4th, and instead of dropping to a normal (say) 2000 rpm, it instead drops to 1500 rpm for 3 sec before popping back to 2000 rpm?
RPMs are dropping & losing power: not the clutch.
How many miles on the vehicle? Maybe time for new spark plugs. Stick with OEM.
Maybe time to clean the MAF. I hope you haven’t wasted money on an aftermarket intake tube.
Check fuel pressure. These cars have a “lifetime” fuel filter.
Maybe your old friend wound it up too tight and cracked a ring. Test compression.
