What r the symptoms of a gummed up carburetor?
Your 2005 Camry does not have a carburetor .
It does, however, have a throttle body, which does essentially the same job. I figured someone should give a constructive response. Here are the symptoms of a dirty throttle body: Symptoms of a Bad or Failing Throttle Body | Autoblog
Low idle and a sticking (closed) throttle, from my experience, are the main two symptoms of a throttle body that needs cleaning.
