The gear selector on my 2005 Mazda 3 with automatic transmission is difficult to move between P, R, N, and D positions. It does not “click” or fall into position like it used to. It has gradually gotten worse. When the car is in Park, it seems to not want to go all the way up into the Park slot. Even though the car actually parked, the P will not light up on the dashboard, which sometimes causes the car not to start when the key is turned. So sometimes I have to put it in Neutral to start.
Now the problem is that when it is in Drive, it will “fall out of gear”. I put that in quotes because it is still in drive, but it was shift up to a higher gear if i don’t physically pull the gear selector knob back. For example, if i’m driving and the car is in 4th gear going 60mph, and the shifter know slides up an eight of an inch, the D light will go off and the car will move into a higher gear (not sure which one, feels like 2nd or 3rd) and the engine will rev up. It doesn’t feel like neutral.
Is there anything I can do myself? I plan on trading in the car in the next couple months, but I’d prefer to not have to get it worked on until then.
Thanks for the help.
