with the foot off the gas on a level or very slight downgrade the car will not slow from 38 mph. the tach will drop to 1000, then bounce right back up to 1250
If the car is still under warranty, take it to a dealer. A vacuum leak or bad idle air control valve can cause a fluctuating idle. How does it idle in neutral?
