2005 Honda Civic Sdn - sending unit code
I have a 2005 honda civic ex the check engine light came on the code read it was a piece that had the oil sending part with it and it was put in cleared the code drove less than d miles the light came back on and had the code ran it says the same part again
It may not be the sending unit. You might have low oil pressure. A mechanic can check the true oil pressure with a gauge.
Wow, You actually understood that run-on, no punctuation, mess of a non-question??
+1 to @Purebred
Yes, step 1 of a 12 step program to be less snarky.
Where is the fun in that ?
Yes, I did notice a bit of snark in an adjacent post!
I am also at step 1…
Not to worry, recidivism rate is high.
