2005 GMC Canyon- Electrical issues
windows will not work cant lock car or move side windows . fuses all seam fine
this may help…
Power Windows/Mirrors/Locks Not Working? - Replace Main Accessory Power Fuse 02-06 GMC Envoy - YouTube
if not it can be a relay or the master switch on drivers door.
if the master switch is bad the windows will still work when using the buttons on the other doors.
There may be a problem with the BCM.
Does the car otherwise work ok? It cranks and starts and you can drive it, right?
Old car with electrical problems…
Check for corroded ground connections first.
