this car makes a heavy clunking sound near the right front under-body over a bump at low speeds. Has anyone had this experience and been successful in determining the cause and effecting a successful repair?
Yes, I have. In my case it was a worn out anti sway bar bushing. Effecting a successful repair cost about $5 and tewnety minutes lying on corrgated cardboard.
There are other possibilities. A loose cat converter heat shield is one. That can be repaired by wrapping a $1.29 large worm-type hose clamp around it, agin with the cardboard.
A worn bushing on a sway bar link is another possibility. About $5.
Kissing the top of the speed bump is another possibilty…as a cause, not a fix.
A bad strut mount does this also.
Or any of a dozen other things.
Man, you’re gonna have to get under the buggy and probably the hood to find the source. Sorry.
Thanks for the response. I suspected the cause was most probably related to loose or worn bushings/linkage-of which there are several. I’ll check out the anti sway bar first. Looks like it’s the cardboard thing.
You mentioned a bad strut mount. The word strut means diffeents things to different people. Are you referring to the mounting for the shock/coil assembly?
