can’t manually shift when using the +/- button on shifter and in the “L” selection. Any ideas ?
Does it shift fine otherwise, ie, not in the manual mode?
how many miles on this, and have you ever had the transmission serviced (fluid change) ?
post withdrawn
The button is just that, a button. One that moves with the shifter. They wear out or the wires get damaged. I’d suggest the button needs to be replaced or there is a broken wire. Either way, you need to open up the shifter to test or find the problem.
Leave it in drive then try the buttons.
