2005 Buick Rainier - Charging issues
thought battery was bad came out 3 days in row to dead battery replaced battery next day it started but alt. was charging at 14.5 normally stays at 14 charging system good alts. fine think I have a draw any any common draws on raniers something staying on someone said ignition switch was gonna pull fuses one at a time to try to determine wwhat circuit the draw is on any sugestions
I suggest adding punctuation and capitalization to any further posts to make it much easier to read and understand.
That said, my go-to for parasitic draws in ANY car are 1) Aftermarket radios and amplifiers. 2) Aftermarket car alarms. and 3) Aftermarket remote starters. If you have any of those disconnect them first.
