i have a 2004 volvo v70 with a manual transmission. i got a manual transmission because i wanted less electronics and simplicity - less things to act “stupid” and break. i was wrong. this this has begun refusing to start, i have it towed at no small cost & the car starts at the shop. the last time this happened the car would also die while driving , so after replacing the starter relay, & the clutch idiot safety switch and lastly the ignition switch it began behaving itself. not it’s doing it again. refusing to start, towing & starting at the shop. there are apparently no error codes so unless t stays dead the mechanics can’t fix it — i want to bypass the clutch pedal sensor - i don’t use cruise control and i have always driven a manual trans - this will be one less useless piece of crap to break. if i short the connector what else does it effect? what else could cause erratic behavior & not generate codes. i really hate cars made after they introduced computers; they are very flakey and and impossible to diagnose because of halfassed implementations of their control systems.
Related topics
| Volvo V70 clutch pedal position sensor | 20 | 9108 | November 13, 2018 | |
| Volvo V70 having trouble starting | 2 | 1508 | October 17, 2007 | |
| 2000 volvo v70 non turbo | 1 | 311 | December 22, 2007 | |
| Another Volvo that won't start | 20 | 30266 | June 22, 2010 | |
| 2000 Volvo V70 intermittent start problems - NO ONE CAN DIAGNOSE! HELP! | 9 | 7943 | November 4, 2009 |
