I have a 2004 montero sport was running fine shut it off now it is not turning the camshafts broke timing belt ? Another question if it broke the belt starting or shuting it off does that lessen the likely hood of bent valves ?
This is doubt?
Nope. Why do you ask?
Related topics
| 2004 Mitsubishi Montero Sport - water pump | 5 | 1238 | November 11, 2020 | |
| Timing belt | 10 | 524 | November 10, 2008 | |
| Mysterious Non-Running Engine Diagnosis: 1992 Mitsubishi Montero Sport RS | 2 | 987 | August 11, 2010 | |
| Can broken Camry timing belt bend a valve? | 16 | 14739 | December 29, 2010 | |
| Driving with bent valves | 18 | 27656 | June 5, 2018 |
