2004 Jeep Grand Cherokee radio screen goes blank
Radio screen goes blank. Radio, time, etc., works, though. is there a separate " fix " for this ?
you can check your fuses to see if one is bad. but most likely it is time for a new radio. sorry for the bad news. if you do a search, you will see that most times when this happens you need to replace it. aftermarket is your best option. one from a junk yard will probably have the same problem or shortly after. jeep/ dodge have had lots of radio problems over the years. even newer years.
