AC_heater/dash_boards_vents_do_not_work
Are you saying there’s no air blowing? That’s a problem with the fan or switch. Start by checking the fuse since it’s the simplest.
Tralblazers, Envoys, Ascenders all had some issues with mode actuator motors breaking in the dash . If you can hear the fan blowing then this is a likely culprit .
