My 2004 Ford Freestar SEL (the 4.2L version, 123,000 miles) is missing. The computer code is P0302 which, from what I can find, indicates a misfire in cylinder 2. I had this same code at 99,000 miles and ended up having the spark plugs and wires replaced around 100K miles. It was all running fine until about a month ago and started misfiring again, badly. I thought it was related to the rain but it is doing it all the time now. At times it gets so bad, I have no power and the computer disengages my A/C (bad at this time of the year). I tried a running a fuel system cleaner that specificially mentioned cleaning the injectors, hoping the problem was simply a clogged injector, to no avail (I know I probably wasted my $10 here). I have a couple of questions:
1. Am I doing damage to the engine or transmission by continuing to drive it? I really don't have a choice but need to know how urgent it is.
2. Does this thing have a traditional distributor cap & rotor or is there an electronic ignition module the plug wires connect to?
3. Where would I find the illusive distributor or ignition module, in theory?
4. Any other theories as to the cause of the misfire (cheapest first)?
