Grumbling noise when put in gear and held with brake. When driving, metal on metal screeching noise. At a stop, transmission felt engaged and the engine almost died. Rough shifting from one to two.
What parts need to be looked at in the transmission?
Mileage, maintenance history, other symptoms (if any)??
Changed the serpentine belt lately? The tensioner?
Changed the plugs lately? How’d the plugs look?
Done a tuneup lately?
Checked the tranny fluid level?
Have you had the ECU scanned for codes?
A failing motor mount might be part of the problem. But if there is a failure in the transmission it is unlikely that anyone would open it to replace a failed componemt. When an automatic transmission is removed and opened it is usually overhauled/rebuilt.
In all practical terms, you can’t just look at parts in the transmission. If you’re looking in the transmission, then you’re just all in at that point. The best thing these days is probably just to drop in a reman unit from a reputable company with a good warranty.
Thank you all for the input. No check engine light, problem is in the tranny. I was thinking the torque converter is failing to disengage when the rpms drop. What say you all? Would anyone replace the torque converter?
The torque converter is possibly the cause for your problems but I would recommend getting a diagnosis from a highly regarded independant transmission shop before making a decision.
I would do nothing without as a very minimum scanning the ECU for stored fault codes.
The even better approach is to follow Rod’s recommendation and get an analysis done by a competent independent shop. Diagnosis is always cheaper and more successful than guessing. In most cases, those who begin by doing parts-swapping end up doing diagnosis anyway. Might as well start with the diagnosis.
The transmission controller needs to be scanned for fault codes. The onboard diagnostics are sophisticated enough that an experienced shop (not a Cottman or similar) will likely be able to tell what’s wrong with a test drive and the results of scanning it.
But based on your symptoms, it does sound like it’s possible that the torque converter has a problem.
