I’ve been having several issues with my Camry. I was able to start my Camry just fine these past few days, but my open door indicator light sometimes shows up, and sometimes none of my lights show up when I attempt to start my car. I had it jump started, and I noticed sparks from the jumper cable when clamping them on. However, my car ended up dying when I went to a stop. I had trickle-charged my car for 16 hours with 2 amps two days prior because it was unable to start.
When I turn my key, no sound is made, but the lights might flicker. I noticed my engine becoming weaker/quieter while driving, and it eventually stopped running. I couldn’t start my car, but my warning lights worked for a few minutes. After several minutes, I could start my car again and was able to drive to a parking lot. After that, I wasn’t able to start it again… I can’t determine if it’s the alternator or something else. Any advice is appreciated.
It’s similar to this: 2001 Toyota camry acts like it won’t start and then barely starts. The weather’s been below freezing if that is any help.
