The a/c in my eclipse cuts of after driving for about 30 minutes. Air is cool while the car is running the gets warm after about 30 minutes. This has been happening for about a month. There isn’t any noise coming from the car. Any suggestions.
I would suggest a good A/C shop. Up north they are often radiator shops. What ever you do, don’t go to a fast oil change place.
You may have a slow leak. Just adding coolant might fix it for a while, but not likely for long and it could cause damage.
Do it right and find the leak and properly put a vacuum on the system before re-charging it, is your best bet.
