does anyone have detailed instruction on how to change the bearing.
Unless you have a special tool (One is called a Gatorgetter.) to remove the bearing from the spindle ON THE CAR, you will have to remove the spindle assy and use a press to remove and reinstall the bearing. In most cases you will find it far easier to get another spindle from a salvage yard.
thanks for the info. I guess I’ll be taking the spindle off.
