My car is surging like the fuel pump might be restricted but it also seems not to be exhausting properly I’m wondering if I have a catalytic converter going out and how can I test it
What makes you think
A restriction in the exhaust is possible. You can test the catalytic converter by disconnecting the exhaust pipe that leads into it or by disconnecting the oxygen sensor. If the car runs better you’ve found a clogged converter. Whether you’re up for either is up to you. http://knowhow.napaonline.com/bad-catalytic-converter-heres-how-to-know-for-sure/
AnthonyStanley please focus more on details of the symptoms, less on guessing what part is faulty.
When does it surge, like cruising or accelerating?
