2003 Hyundai Santa Fe - persistent battery drain
New battery,new alt.still have battery drain… starter seems fine…no lights on.found cd player ran on when not in use,fixed that checked all lights none on…no blown fuses. >>confused,lol
Something is still draining the battery. Though you fixed the CD player, I would still guess the unit is drawing power. Pull the fuse for it and see how much battery drain there is,
Thanks…Done that too I unplugged the whole unit,still had the drain
The advice usually given is to then pull each fuse, one at a time to narrow down the offending circuit.
