2003 Honda Odyssey EXL with 236,000 miles on it was jerking, very scary, and the rpms were revving up while driving. We asked around and had it checked and was told it was the transmission. We waited 9 months, not wanting to put the money into it and let it sit, not driving it at all. Then we decided to fix it last week.
We thought we were replacing the transmission, but, after working on it, the place we took it - very reputable - only did the solenoid, saying that fixed the problem. When we took it home an hour away, it was fine - much, much better than when we left it. But, the next day my husband felt a small jerk. We took it back that night and left it with them for a couple more days. They couldn’t make the problem recur, so they sent it home with us. We were getting ready to go on a major road trip, so we had the oil changed, and all other stuff for regular maintenance seemed good. Had all fluids checked and new tires on and new battery. Also had recall done on ignition switch. Left on major cross-country trip. Drove about 5 hours and it started again. Just a little - one time. No place was open and we were on deadline, so kept driving cross country.
Eventually the check engine light came on (can’t remember if it was before or after started jerking), but that has been on for a couple years and we keep having it checked and they tell us it is not worth fixing - hard to figure out the emissions problem. Could be several things. One was the solenoid, another the gas cap. We had both those replaced. Problem has gotten worse as we have crossed the U.S. on Memorial Day weekend - so no opportunity to have mechanic look at it or get codes due to everything closed. Checked transmission and oil fluid levels, and they are good.
If we accelerate VERY slowly, we are okay. But, the TCS light comes on if we accelerate too quickly sometimes, and it will stay on until we stop and turn the car off. Sometimes it doesn’t come on at all, but the check engine light is always on now. In the last 200 miles, we now have occasionally the D (drive) light flash - if the TCS light is on and we are getting jerking, and the rpm’s stay up in the high 2’s or close to 3 and the van doesn’t seem to shift into the higher gear. If it flashes, it won’t quit or shift into the higher gear until we stop for maybe 20-30 minutes. Then, the light will stop flashing and the rpms are okay. As long as we accelerate really slowly, really slowly, it won’t flash again. One time, on an off-ramp, we jerked when we were decelerating, but that was only once in about 1500 miles - or ever as far as I can remember. The jerk on acceleration has actually been going on for a couple years, but it was always just momentary and only occasionally. Now it is a problem.
We are on the road, what should we do? I’m scared this will cost us a lot more than if they had done it at home! We were going to buy a newer vehicle, but in the end, decided it was better to have this fixed. Now what?
