I have the same problem battery dies over night all instrument panel goes out when you drive it a while takes at lease ten mintues while driving to come back up
We can’t see the problem you are referring to. Can you explain here and we’ll try and help you.
The battery discharge issue is due to an excessive current drain on the battery while the ignition is OFF. The instrument panel issue could be due to just a loose connector going to the panel. If you aren’t a do-it-yourselfer then take the vehicle to a shop and have them check those things. Any decent shop should be able to fix those things pretty easily. They are simple problems to find and fix.
