2003 Acura MDX - Battery Discharges and Vehicle Will Not Start
Each night, open the fuse box and pull one or more fuses overnight. If the problem still happens, then you can rule out those circuits. You might be able to narrow it down to a specific circuit this way.
By the way, I should point out that you got a bit lucky with your timing belt. It was two years overdue. Had it broken, you’d be paying around $4,000 to replace or repair your engine.
