2002 Honda Civic Cpe - Battery drain
I have a parasitic battery draw. Both the battery and the alternator are healthy and aren’t causing the problem. and I cant get my hands on a fuse puller to test them
Do you have a small pair of needle nose pliers?? or some good steel tweezers??
You will have to invest in some tools including a decent DVOM (Digital Volt/Ohm Meter)…
Or find a shop that knows how to check for current draws…
Here is a link to some really good info about parasitic draws…
You can buy a fuse puller for $10. If you want to troubleshoot the problem yourself, this is a cheap tool to buy.
Check your fuse box. Many cars have a little plastic puller included, but I just use my fingers.
Use a fuse to pull another fuse.
That would be helpful if a 2002 Civic used standard-sized fuses, but it uses mini fuses:
good heavens people you can buy a fuse puller for less than $5 or just use a needle nose. this aint rocket physics. Hell, you can even use a small pocket knife.
Yes. It won’t let me hit the like button either. Says to come back in 41 seconds. But yeah if you can’t figure out how to get a fuse out, best to just take it to a shop before someone gets hurt.
