after rocking my car to try to get it unstuck in snow my idle will not come down it is very high to the point where i odnt feel comfortable with the car running any suggestions???
Check the throttle linkage. Another possibility is that you managed to pull the vacuum line loose on the front axle (if you have 4WD).
