2001 Toyota Tacoma knocks when AC belt is tightened
Previous owner had disconnected the AC My mechanic hooked it up but when the belt is tightened it make a knocking sound louder when under load. He could not find the cause. When the belt is loosened it goes away.
The truck has 123,00- miles on it and had been sitting for 6 months before I got it. Finally just had him put the belt back on and the knock hasn’t got any louder.
I assume you mean when the A/C is on? I am surprised your “mechanic” could not find the cause. A simple stethoscope could probably tell whether or not the knocking comes from the compressor. Cold be one of the compressor’s piston is going bad or the A/Cs pulley is on its way out.
Check the harmonic balancer also. One thing you do not want is a loose or worn balancer knocking on the crankshaft nose. That can lead to crank damage which means major motor work.,
Find the source of the sound step 1. One could hope it is a bad tensioner.
Sorry I forgot to mention he replacedvtge compressor but the knock was still there
That’s a good bit of info. New compressor. No belt. No noise. Related?
In that case Barkydog may have the right idea… belt tensioner … or any other accessory with a pulley.
However, it is possible to over tighten a belt and causing a pulley out of alignment and causing the knocking. If all accessories run OK, battery charges, power steering works, A/C work with the belt loosened a bit I would keep it that way. A stethoscope is still the best way to identify the source of an unwanted noise. Heck, a simple 2ft piece of garden hose will do it.
I don’t like to say this mechanic is in over his head but it just does not seem like it would be that difficult to locate the source of the knocking.
I will just reiterate what I said earlier about checking the harmonic balancer. If it’s not too late already.
