2001
Toyota
Echo
1.5 Liter Automatic
213K miles
My car will start fine but when I start driving it will periodically sputter, particularly when I push on the pedal. If this was my old car I would immediately change the plugs, wires, cap and rotor. But it has electronic ignition so has no wires, cap and rotor. I just changed the plugs a year ago, less than 10k miles ago, so I doubt if it is that.
So, moving to the fuel system I thought I would change the filter, but the filter is integrated into the pump which is in the tank, and it like 125$. And it seems like to me that it is unlikely for that electronic pump and filter to need to be replaced hardly ever. I could be wrong.
So, what else can I test? There are no codes, so I doubt if it would be mass airflow sensor or something in the air intake. Could it be a leak in the air intake?
