How much should it cost to replace the fuel tank heat shield on the 2001 Toyota Camry?
see your other post about the vacuum valve. Same answer.
Related topics
| 2001 Toyota Camry repair question | 1 | 366 | August 2, 2011 | |
| 1999 Toyota Camry - Replacing Vapor Canister, Anything Else? | 0 | 289 | August 11, 2019 | |
| 2010 Toyota Prius - Heat shield costs adding up | 1 | 3566 | February 12, 2020 | |
| 2012 Toyota Camry manifold heat shield | 6 | 1016 | November 26, 2020 | |
| 2016 Toyota Camry has a loose heat shield | 3 | 2322 | May 11, 2020 |
