2001 Honda Odyssey ABS and TCS lights stay on
2001 honda odyssey abs and tcs light stays on even after brakes changed and with reset
Then there is a problem with one of the two systems. You’ll need to get them diagnosed and repaired, as they are non-functioning at this time.
Is the Check Engine light also lit-up?
If there’s a problem with the ABS, the TCS light will automatically come on because it won’t function if there’s an ABS problem.
