We have been having a recurring check engine light. The code is always P0422 evac small leak. Here’s a list of repairs so far:
replaced vent valve 42084Fa120
Subaru gas cap
Subaru Dealer replaced the following parts
2 11044AA633 Gskt cylendar
4 10966AA000 Gskt Spark Plugs
2 13294AA053 Gskt Rocker
10 13271AA071 Washer Rocker
2 14035AA383 Gasket intake
1 13073AA190 Idler Cp Bel
1 13073AA142 PT340292 IDL
1 13085AA080 Idler Cp Bel
1 13033AA042 Adjuster Ay
1 21111AA007 Water Pump
1 21114AA051 Gasket Water
1 21200AA072 Thermostat
1 21236AA010 Thermostat G
2 44011AC030 Gasket
1 15208AA12A Elem CP Oil
1 11126AA000 Gasket
5 12345616 Oil 10W30Q 8.8
Next day the check engine light was back
So…found head gaskets leaking and replaced head gaskets under parts warrantee
found heads warped - sublet for repair mill and press chk heads
So…replaced faulty electrical coupling.
This time the light stayed out for 3 days, but now it’s back. Help us, we love this car!
I can't say all that was not needed, but much if not most of that list would have nothing at all to do with the code as reported.
I suggest that you replace one part. That part is the dealer or whoever is doing this work. Find a good shop.
I’d start with checking the evap cannister lines going to and from charcoal cannister and fuel tank. You might have a slightly loose or cracked vac line, or shutoff valve sitting on the cannister or near it. Sounds like you did a whole lot of preventative maintenance (wow, even shaved the heads), now is the time to start troubleshooting the real problem.
