I purchased a 2001 Ford Focus 7/17 from a Ford dealer. I paid $995 for an inspection, of which the Ford dealer said no issues were found. The car broke down 14 days after purchase.
While my daughter was driving, at a left turn, the engine light came on, the car stalled, and the steering wheel and gas pedal locked up. A friend did a computer scan and said the code came back that 2 sensors, the crank shaft and cam shaft sensors, needed replaced. So we had them replaced.
About 4 days later, while driving home from school, on a right turn, the car broke down again on my daughter. She said the symptoms were the same, engine light came on, car stalled, the steering wheel and gas pedal locked up. So we had it towed to a local Ford service department. They said the ignition coils needed replaced and the valve cover gasket would eventually need replaced (per the mechanic, this wasn’t directly related to the issue but a small leakage was found). So we let the Ford mechanic replace the coils and the valve gasket cover. They ran several tests and put 20 additional miles on the car without failures or issues, scans came up clean.
So while driving to school this morning, on a u-turn, my daughter experienced the issue again…car stalled, engine light came on, steering wheel and gas pedal locked up. After sitting a few minutes, the car started up so she drove it home and hitched a ride from dad to get to school.
Ok, so we’re stumped. We just got it back from the mechanic on 8/10…any ideas on what is causing this issue so we can get an idea of what to repair?
