this truck has the x-tended cab and is 4 wheel drive. It began making noise and vibrating at high speed the other day…like when driving on the out-of-bounds drunk bumps. I found that when I engaged the 4-wheel drive transfer case, with the hubs unlocked, the noise went away for a brief period, but then would start again…especially after hitting a bump in the road. The noise & vibration will happen at any speed. It was suggested it might be the carrier bearing, but I checked that (pulled the drive-line) and it is tight. I had to back out a trailer in 4-wheel drive the other day and the phenomenon went away for several days, but is back now. With the windows down I can hear a clacking sound (not a clicking sound) that goes along with the vibration.
Solarboy
1
Worn universal joints on the drive shaft maybe?
Related topics
| My truck sounds REALLY bad | 8 | 935 | September 29, 2011 | |
| Vibrating between 43 and 54 MPH | 20 | 4102 | July 25, 2016 | |
| Vibration on the highway | 3 | 784 | March 9, 2011 | |
| F150 drivetrain noise | 2 | 589 | July 7, 2008 | |
| RWD rear end vibration | 12 | 7177 | April 11, 2017 |
