Shuts off when gets hot
You have a problem.
That’s is all I can say considering you told us nothing about your car and very little about your problem.
If you want more help, give us more information.
I’m assuming the engine stops when the truck gets hot, or rather operating temp. Pro mechanics, could this be a crank position sensor issue?
The CPS is a likely candidate for the trouble. It would help to know if there are any error codes generated when the problem happens. The trouble is most likely within the ignition system somewhere.
How long do you have to wait until you can start it again?
What is ‘hot’?
190 on the water temp?
260 on the water temp?
70 degrees outside?
100 outside?
150 outside?
When the flames start shooting out from under the hood?
Eddo, when the tea water is boiling…
