After removing the bolts, what is the recomended procedure for separating the steel hub from the aluminium swing arm?
The combination of these two tools. http://www.northerntool.com/webapp/wcs/stores/servlet/NTESearch?storeId=6970&in_dym=1&Nty=1&D=than&Ntx=mode+matchallpartial&N=0&Ntk=All&Ntt=hub%20puller&cmnosearch=PPC&cm_ven=PPC&cm_cat=I-search%20(Google%20Adwords)&cm_pla=unproven&cm_ite=hub%20puller
