heater blowing cold air ,climate control working ,actuator door working,water going into core hot coming out cold
Coolant constantly flows through your heater core, whether you want heat or not
So you’re talking about the blend door actuator . . . ?
So you’re saying one heater hose is hot, while the other is cold . . . ?
Assuming the engine had reached proper operating temperature when you made that statement . . . your heater core is at least partially plugged, maybe completely
