When I start the car, the motor will rev up or down and sometimes kill. Then the rpms go back to normal, about 850. What is going on?
The idle air control valve may be sticking. Use Throttle Body Cleaner to clean the idle air control valve passages, and the air intake air passages of the throttle body.
