I want to answer the e-mail about changing the fuel pump relay, and the answer is yes , I changed the relay and then the ignition switch but I still have the problem so I took my voltmeter and check for power at the relay socket and foun no power so I place a jumper from the positive of the battery to the relay and feed power to the fuel pump which ran fine and the engine ran good, then I replace the relay and the next day I try againg by crancking the engine as if nathing was rwong and it ran good, so What can cause this problem? the question remains the same.Thanks for your help
Related topics
| 2K Silverado Pick Up | 2 | 530 | December 31, 2009 | |
| 2002 Chevrolet Silverado 1500 has trouble starting | 4 | 758 | April 21, 2021 | |
| 2k silverado fuel problems | 5 | 986 | January 31, 2010 | |
| 2 fuel pumps in 3 months? Why? | 12 | 21602 | July 11, 2009 | |
| F150 ?fuel pump relay | 7 | 1212 | January 28, 2013 |
