My van’s air conditioning and heater blower stopped working. I don’t feel any cold or hot air coming through the vents. The same situation exists with the ceiling passenger back vents. What do you suggest I do? SPD
First check the fuses and relays.
If okay, try tapping on the blower motor, if it tries to run it needs to be replaced. If it doesn’t, check for voltage at the motor.
